Today’s Machining World Archive: April 2010 Vol. 6, Issue 03
We are running a long aluminum part on our CNC Swiss and have problems with the long stringy chips building up in the machine and getting wrapped around the part. We’ve tried every “aluminum” insert under the sun and have 2,000 psi coolant, but nothing works. Please help!
Tangled Up in Tennessee
Dear Tangled,
There is a new chip control technology for aluminum that I’ve found to be very effective. It’s a PCD (polycrystalline diamond) insert that has a 3D chipbreaker. Up until now, manufacturers have been unable to produce 3D chipbreakers in the ultra-hard polycrystalline diamond material. A new process has been developed that uses a laser to etch a variety of 3D chipbreaker shapes into the PCD. The inserts are made by Becker Diamont.
They have a video on YouTube that can be found at: www.youtube.com/watch?v=gLRJdMDvbpY. A brochure can be downloaded at: www.ranitool.com/ChipBreaker-ranilowres.pdf.
On a Swiss I’ve found that it’s the feed rate that is critical to getting the chip to break. In general, a larger depth of cut requires a slightly higher feed rate. On a fixed headstock lathe, you can also vary the depth of cut and the feed rate for optimum results.
Other possible solutions include milling a flat or narrow slot along the length of the cut before turning. I prefer to use a narrow slotting saw to cut an off-center slot along the turn length. A narrow slot has less chance of generating an out-of-round condition on the turned diameters. Milling the slot off of the centerline of the work prevents the slot from hitting the turning insert squarely. The slot being off center along with the rotation of the work causes the slot to hit the insert and travel by it on an angle. This eliminates any pounding caused by the interruption while providing enough interruption to break the chip.
Problems with grooving and cutoff tools can often be solved by using a peck cycle like G75, which is like a peck drilling cycle, but from the cross axis rather than along the Z-axis.
Ultimately these other options add cycle time while the PCD insert will likely reduce cycle time and improve uptime.
You will pay more for PCD, but it almost always costs less than a polished carbide insert due to the vastly improved tool life.
Another added benefit is that once you start breaking the chips up, you won’t have to empty out the chip bin nearly as often. Those long wiry chips create big air pockets that take up a lot of space.
Dan Murphy
Tsugami REM Sales
Try pecking!!!
Based on the machine model/type, there may be a standard toolholder available that will work with your HPC system to help break the chips.
See http://www.myyellowcoat.com/smart-ideas/high-precision-coolant-qs/
Are you using 6000 grade aluminium – if so see if your customer will agree to change to 2000 grade aluminium which chips just fine .
