Today’s Machining World Archive: September 2006, Vol. 2, Issue 09
Lisa Bailey-Beavers, national sales manager of GTI Spindle, inspects a Heald grinder dressing spindle.
Everything wears out eventually, and the spindles in machine tools are no exception. Though many shops could theoretically rebuild or repair their own spindles, many choose to send them out—back to the manufacturer, or to a company that specializes in rebuilding and repairing them.
One such company is GTI Spindle Technology, Inc., in Manchester, NH (see sidebar). GTI Spindle repairs and rebuilds a wide variety of spindles from over 300 manufacturers. They rebuild tiny spindles used in machines that wind light bulb filaments; large spindles used in enormous machining centers; spindles in machines that grind the titanium parts for artificial hip joints, cut and polish granite countertops, saw and rout wood for assemble-it-yourself furniture, hone razor blades and even curl the hair on dolls.
First look
At GTI Spindle, when a spindle arrives at the plant, it is logged into the tracking system. Information about each spindle is available online for customers to track their spindles through the process.
Next, the spindle is evaluated. If it isn’t broken in any obvious way, it is run on a test stand and a vibration profile is taken. A sensor (an accelerometer) is attached to the spindle housing. As the spindle rotates at different speeds, the sensor detects how much it is vibrating. A vibration analyzer takes in the signal from the sensor and prints out a graph showing how severely the spindle vibrates at different frequencies. The vibration signature can help diagnose problems, including out-of-balance conditions and bearings that are failing.
Vibration testing can also help determine there is no problem. Quite often, GTI Spindle receives perfectly good spindles that have been sent out for rebuilding. “One in twenty doesn’t need repair,” according to GTI Spindle president Thomas Hoenig. In these cases, sometimes a little detective work is needed to diagnose the trouble.
Hoenig recalled the case where every fourth part from a customer’s machine was bad. The spindle came in for repair, but there was nothing wrong with it. The customer, helped on-site by a GTI Spindle technician, eventually discovered that the problem was a hydraulic pump mounted to the bed of the machine without benefit of an isolation pad. When the pump turned on, the vibration disturbed the machining process. In another case, vibration from a compressor in the next room actually interfered with machining.
Looking inside
After vibration analysis, the spindle is carefully measured for runout and other parameters. Then, the technician disassembles it, looking for signs of wear, fracture or other modes of failure.
Richard Bourgeois, breakdown technician, performs runout measurements before disassembling a spindle.
“Eighty percent [of spindles] fail from contamination in the bearings,” Hoenig says. “Contaminants migrate from the coolant or from air/oil lubrication.”
As the disassembly process continues, the parts are cleaned, examined, measured and sometimes photographed. By the time disassembly is complete, the technician has a pretty good idea what is wrong with the spindle. Each spindle’s components and paperwork are stored in a plastic bin. At this point, the customer receives a diagnosis and a quote for the repair.
Putting it back together
When GTI Spindle gets the go-ahead from the customer, the repair process commences. Parts are repaired or replaced, as appropriate. Parts damaged in a
A display of spindle components made in GTI’s machine shop: (Front, from left) a shaft, a rear housing cap, two labyrinth rings and two spindle housings. (Rear, from left) a stator housing, a shaft, two rear shaft nuts and a front shaft nut.
crash might be resurfaced, welded back together or replaced with new parts machined in GTI Spindle’s machine shop, says Hoenig. Bearings are replaced. Tapers and other surfaces might be reground or could be resurfaced through a process called grind-plate-grind, in which they are ground, sent out for replating and then ground to resize.
A well-balanced spindle
Near-perfect balance is critical in high-speed rotating parts such as spindles, to keep them from vibrating and affecting the accuracy of the machine in which they are installed. At GTI Spindle, individual rotating components are first balanced, then after the spindle is reassembled, the entire spindle assembly is balanced.
The balancing operation is similar to dynamically balancing an automobile wheel with a tire mounted on it. The part is rotated on a balancing machine that indicates where the imbalance is. On a car wheel, weights are added to offset heavy spots.
On most spindles, material is removed opposite lighter spots that could be due to voids in a casting or other causes. An occasional spindle will allow for adding material, such as the large Makino spindle (see below), to which you might add weight by installing setscrews into threaded holes in the shaft, provided for this purpose. Large spindles that are too big to fit on a balancing machine can be balanced using a vibration sensor and a strobe lamp.
After the spindles are rebuilt, GTI Spindle operate them for at least eight hours to run in the bearings and make sure everything is working properly. Specially designed test stands hold the spindles, power or drive them, provide lubrication, compressed air for air bearings; whatever the spindle needs to run properly.
Special stand
Some spindles are especially demanding in what they need to run properly.
Applying the strobe to a Makino spindle.
Makino spindles, such as the one shown above, which is from a vertical machining center, contain passages through the shaft and bearings for oil that lubricates and also cools. This type of spindle cannot be run at speed “on the bench” without its oil supply.
GTI Spindle spent a year and a half and footed the considerable expense to develop a special Makino spindle run-in stand that includes pumps, coolers, vacuum oil recovery and other features. Now, at GTI Spindle, these units can be properly exercised and tested before being shipped back to their owners.
Sending them home
Finally, after the reassembled spindles have been run in, measured, tested and found good, they are painted, if appropriate, and packed in wooden crates for shipping, cushioned by conforming foam. Along with the spindle, GTI Spindle sends the customer the spindle’s records, failure analysis report, if any, and all parts that were replaced.
Spindle maintenance, repair and rebuilding can represent a large expense for even a moderately-sized plant. “Customers who spend $50,000 to $ 1 million a year can save 30, 40 or 50 percent, of new replacement cost” says Hoenig. Signifi cant savings can come from maximizing spindle life through proper maintenance and correcting the problems that cause failures. Preventive maintenance, including scheduled rebuilds, can also keep unexpected downtime to a minimum, keeping machine hours and revenue up.
Even though you can depend on spindles to fail eventually, there are ways to plan for failure and minimize its effect on your business.
A different spin
Besides sharing information and engineering aid, the company goes even further. “We’re training our competitors,” says Hoenig with a bit of a smile. Indeed, if a customer decides to do its own repairs, GTI Spindle would lose that business.
GTI technical director Raymond St. Onge checks runout on a spindle shaft.
But, if that customer wants training on how to repair spindles, GTI Spindle will happily provide training. Of course, once a customer finds out what is involved in rebuilding spindles, he or she may decide to continue letting GTI Spindle do the job.
On one Thursday in July, representatives of two major corporations were visiting the Manchester plant. The head of the spindle repair lab at a well known aerospace company was training on how to rebuild Makino spindles.
Two plant engineering staff from the state of the art Hyundai factory in Montgomery, AL, watched as GTI technicians rebuilt spindles from their plant. Hyundai engineer Nick Harsanyi said he and maintenance technician Ricky Speaks were “training, learning and evaluating [GTI’s] services.” Their department is responsible for over 150 spindles in the CNC cell that manufactures heads and engines for the Sonata and Santa Fe vehicles, Harsanyi said.
Besides GTI Spindle’s headquarters in New Hampshire, the company has facilities in Bloomington, IL, Romulus, MI, and a spindle and machine tool repair shop onsite at Caterpillar Fuel Systems in Pontiac, IL. For more information, visit the company’s web site, www.gtispindle.com.
