OK, cold rolled 1018
hole drilled thru 1/2" steel with Morse #7
OSG hy-pro spiral point 1/4-20 tap, destroyed
using regular coolant (cim-cool) like always
float tap:
1000 RPM
F45.
rigid tap:
1000 RPM
F50.
We used to run this program at about half the speed with cheap china made taps and would run all day
Now we got good taps and I thought 1000 RPM would be no problem. I hear a lot of folks use 1000 as a standard since it makes feed calculations so easy.
The taps are breaking though, and sometimes the threads look like garbage, all chipped and hard to screw in. When the taps break, theres srtrings of chips jammed in beside the tap and hanging out the bottom of the through hole.
So it looks like 1000 is too fast for the chips to push ahead of the spiral point.
Sound about right?
sure surprises me...
backing it off to 750rpm for now
