Across
1 Tool condition problem with particles adhering to the cutting edge during chip removal, abbr.
4 Microprocessor-based controller, for short
6 Molding process which allows the rapid molding of liquid materials
7 Rotating tool with teeth arranged in a helical path
8 Rotary tool that removes hard or soft materials
10 Cutting-fluid additives that minimize chipwelding, abbr.
11 Tool coating process performed at low temperature, briefly
12 Direction of the predominant surface pattern
Down
2 Operation in which electrical current flows between a workplace and conductive tool through an electrolyte, abbr.
3 The portion of the tool body that joins the lands, on a rotating tool
5 Impact test in which a V-notched, keyhole-notched or U-notched specimen, supported at both ends, is struck by striker
6 Angle of inclination between the face of the cutting tool and the workpiece
9 Out of the ordinary
[...] This post was mentioned on Twitter by David Dickerson, Amy Reynaldo. Amy Reynaldo said: Crosswordy people, marvel at this puzzle: http://www.todaysmachiningworld.com/crossword-by-myles-mellor-2/ . Why isn't 9-Down ADZ? [...]
